Use the following procedure to configure Wake-On-LAN functionality.
The following table defines parameters for the eapol traffic-control command.
Variable |
Value |
in |
Specifies incoming traffic is blocked when there is no authenticated device. |
in-out |
Specifies incoming and outgoing traffic is blocked when there is no authenticated device. The default value is in-out. |
